Geometry check errors
serdagi
Hello, in our attached project, we cannot fix the errors that occur as a result of geometry control. For example, it says faulty flooring, but there is no such flooring. I would like your help on how we can fix the errors. I wish you good work.
Objects remain at 0;0 point on ground and 1 floor. There is no problem when you delete them. Get a geometry check. Say select related objects. then delete it.
As I said: first check the geometry Select objects with the same results on the relevant floor and say. then exit the geometry control. say delete without doing anything. they have been selected and deleted. Do the same for the other floor.
