Hi My Suggestions: The coordinates given as a template are seen in the project. The solution was made by taking the Eskişehir-Tepehead coordinates and arranging the column, curtain, raft plate, floor. Check. If the soil bearing strength value you gave is correct, the ground It is very low because it is ZE I entered the soil bearing capacity qt=16.5 t/m2 but it saves (There is a little minus value.) In this case, the soil can be improved by making soil improvement The bearing capacity value should be subtracted from 16.5 t/m2. If the ground value you entered is the same as before, the ground safety stress will be approximately 11*2.5/1.4=19.6 t/m2, which is enough for you. Please check. The project is attached. Ünver ÖZCAN
