Friends, I would appreciate if you could help me a lot.
Check the geometry. Select and delete the small objects that appear there. In this way, your project can be analyzed. Also, I suggest you avoid making beams 30 cm high. I haven't looked into other issues. You've already sent one coat. Good luck with.
