Floor reinforcement drawings
M.sa
Please draw the floor reinforcements as polylines, not as lines. There is a serious problem when we have to slide the reinforcements in the cad environment when the pile is used. You can answer that the accessories can be slid comfortably on idecad, but we do the detail drawings in the cad environment, so there are many problems. If this is provided, I think it will be much more useful. good work
Re: FLOOR REINFORCEMENT DRAWINGS We also see that the reinforcement texts are not unified and when the drawing is printed, the length and number texts are printed very far from each other on opposite sides. Much smoother drawings can be obtained if the texts are combined and centered on the reinforcement line.
"M.sa":23lceyao" said:
Please draw the flooring reinforcements as a polyline, not as a line. When the pile is used, we have a serious problem when we have to slide the reinforcements in the cad environment. You can answer that the reinforcements can be shifted in this way, but we make the detail drawings in the cad environment, so there are many problems. If this is provided, I think it will be much more useful. Good work
Hello When you receive the formwork plan drawings, all the flooring reinforcements are drawn as blocks. This block Explode the drawing with the "Break Object" command. All the reinforcements will become separate blocks. In this way, when you export DWG, you can move the reinforcement as a block. You wrote that you do not edit on ideCAD, but if you make these arrangements in ideCAD, it will be much more practical. When editing the drawing, "M" + Spacabar sends the normal move command to "H" only when you press the "M" key. fast move" command becomes active. The quick move command works differently than the Normal move command. It is used to organize and move reinforcement blocks without exploding them. When you enter the quick move command and click on a pillar drawing, the pillar and all the reinforcement texts on it can be moved together. When you click on a text on the pile, only the text is moved.
"M.sa":3k0lzm8r" said:
in addition, we see that the reinforcement texts are not combined and when the drawing is printed, the length and number texts are printed too far from each other on the opposite sides. centered, much smoother drawings can be obtained
When drawing optimization is made, reverse writing of length and reinforcement texts has been corrected. Update 10.59 version and get drawing again. If your problem persists, share your project. Your requests have been noted in our notes.
