Hello there; 1- Remove the lovers from the analysis. 2- Use horizontal cross on the roof both to hold the truss head and to provide stability. These crosses must be defined in the same openings as the vertical crosses. 3- Your choice of R is wrong, you have a structure consisting of C16 in one direction and C13 in the other. 4- If there will be no architectural problems in the sections where the curtains are located, enter a wind column and connect it to the truss with a wind combination. The headers of these columns should now be rotated 90 degrees from the existing column headers. 5- If necessary, increase the column sections.
