Errors that I can't fix in geometry check
No matter what I did on the attached roof, it says the system cannot be resolved, no matter the geometry check. It shows a different node each time. the points shown are the bottom profile of the trusses. no matter what i did. It's urgency. can you help me ?
Re: EMERGENCY HELP SCISSORS ROOF GEOMETRY ERROR Hello; Enter the column supports under the scissors are not visible. That's how it will analyze. Also, you don't have a horizontal cross and stability beam on the roof. Without adding these, it is very difficult for your post-analysis sections to be sufficient. Enter between the two scissors upper heads between the frames so that the horizontal crosses are one full and one empty. You can also create the stability beams by using a pipe profile to connect the other truss subheads from the middle joint of the truss subhead. Connect these beams to the truss sub-head with a cross-end joint. Good work.
