aksualigurbuz
Good work. We want to build an elevator in an existing building. We will connect it to the corridor from the outside. It is a 5-storey building. I also want to model a U curtain. However, I will not combine the curtain with the building under any circumstances. I will not affect it statically. type will have an average of 20 cm thick curtain. Question: Is 1-10 cm dilatation sufficient? Question: 2-When modeling such a structure, will it be enough to try only EGQ loads? If the elevator will also have a dynamic load, how much load can I have from the outside, where? (for a 4-person elevator) thank you, good work everyone
