Hello friends; While deleting one of the elements that are shown on top of each other on the plan but defined at different levels (for example, when I want to delete the beam at the floor level, it also deletes the beam and the floor defined at the bottom with the negative level), it also deletes the elements that appear to be connected on the plan defined at the upper level. the situation is the same. What steps should I do to solve this? (In this plan, it would be nice if an option box opens where you can enter the properties of both or delete them directly when you hover over the elements defined on top of each other)...
