eccentricity
muratkanici
In architecture (8,504 version), I can't give defined offset to the walls and beams from the settings section. First I have to draw and then change the object properties command to correct the offsets. I did not have this problem in previous versions. What could be the cause of this problem? Best regards.
Hello, please check the distance value you gave from the Defined option, if it is more than the wall thickness, the defined offset is not given. Take it easy, good work..
Hello, I'm giving the 25 beams an offset of 10. I have a 25*50 column with a 10-gauge offset. I click at the node of the column, it is connected as 10 deflection, but when I press the space key, my defined eccentricity is canceled and the eccentricity from the top, bottom and middle becomes active. Best regards.
Hello, I suggest you call our Istanbul or Bursa office and describe the situation with remote access. Take it easy, good work..
