The version I am using now is 6.053. Before analyzing the project, I see that only 1975 is active in the earthquake regulation section while making general settings. Other 1997 and 2007 are not active, how can I activate it.
Thank you very much, my teacher. I had one more question. After completing the analysis, I enter the quantity. The amount of iron given is very high. I wonder if we have the opportunity to interfere with the amount of iron.
The fact that the iron quantity is very(?) is the result of a reason. The program prepares the quantity according to the calculated results. Instead of intervening in the quantity of iron, it is necessary to make arrangements to remove less reinforcement in the system. I suggest you do a detailed review...
