Mr. Muhammed, the explanation mentioned is wrong. If Mdev>0.75*M0 is not provided, the indicated system is A33. In other words, since your regulation curtain is not enough, it makes you buy smaller R and D and increases your earthquake strength. Normally, it only allows you to construct a columnar hollow block building only if DTS=3 or DTS=4. But even if there is only one curtain in your building, it allows you to solve in DTS=1, 2, 3 or 4 (A23, A24), it punishes you if Mdev>0.75*M0 is not provided and says follow the R, D and BYS rule in A33. . I hope it's clear this time.
