Earthquake Ground Motion Level ?
badman
Hello, although I chose dd2 in the 2018 directing steps in the program, dd3 appears in the "SPECTRUM PARAMETERS FOR CONTROL OF FLOORS BETWEEN PLOTS" section of the report, how can I convert it to dd2, at which stage of the program or how? I will be very happy if you reply
"badman":3a2q21kf" said:
Hi, although I selected dd2 in the 2018 directing steps in the program, dd3 appears in the "SPECTRUM PARAMETERS FOR CONTROL OF FLOORS PARAMETERS" in the report, how can I convert it to dd2, at what stage of the program or how? =https://www.file.tc/server29/gs4coq/4bc94ee9-6e6b-410c-bb68-ecc91d18d9b5.jpg.html]https://www.dosya.tc/server29/gs4coq/4b ... 5.jpg .html[/url]
Hello, The report you marked in the picture you added is printed because it is used in the lambda coefficient in the relative floor drift control (You can enter this value in the TBDY wizard Design Spectra tab.) The Lamda coefficient that is active in the relative floor drift control depends on the DD-3 ground motion. is the ratio of the elastic design spectral acceleration calculated according to the DD-2 ground motion to the elastic design spectral acceleration calculated for the DD-2 earthquake ground motion Spectral acceleration values for the DD-2 earthquake ground motion can be found in the TBDY 2018 Earthquake Parameters Report and just above the section you marked. e is given.
I want to output as dd2 or I want the report not to be printed, how can I do this? Also thanks for your reply.
"badman":2r103c6d" said:
I want to print out as dd2 or I don't want the report to be printed, how can I do that? Also thanks for your answer
-DD-2 information is already printed in the TBDY 2018 Analysis Parameters report.(In my previous message I mentioned above) -DD-3 values should also be shown in the report for Relative story drift control.
