DRAWINGS OF ANGLE BEAM, ANGLE, COLUMN
tabanlioglu
When we want to take the extensions of the inclined beams, both points are drawn at the same level, like a straight beam. Also, in the same project, inclined column and inclined beam junctions (column vertical expansions) are drawn straight. In the column stirrups (middle of the column), the drawing of the stirrups is blank. When we take the Column-Beam Junction Section, the connection of the inclined column with the beam is again (broken) an irrelevant drawing. The dimensions, elevation, and inclination angles of these drawing expansions I mentioned are not given. I think these problems need to be fixed in the new version. The feature in the previous 5 version is available in this section. However, in the new 6 version, these parts should have been corrected. I hope these issues will be fixed soon, good work.
