drawing optimization
Hello. Especially on floors with small openings, there may be a situation where the texts are intertwined. Before drawing, you can reduce congestion by increasing the distance between rebars by using the Rebar offset distance in the Die plan Drawing properties. You can edit the formwork plan into two formwork plans, Reinforced and Unreinforced formwork plans. Only dimensions and element names can be given in the unreinforced formwork plan, and only the reinforcement drawings in the reinforced plan. After the mold plan drawing is taken, you can move quickly by pressing the M key on the keyboard without exploding the blocks. You can move all the texts on the reinforcement + reinforcement at once, by selecting the reinforcement with the mouse, just press M. If you click on the text in the block, only the text will be moved, M + Space Bar or Move command in the Toolbar will move the whole block,
