Double column on single foundation
memorandum
Greetings, I don't want to dilate the foundation, but a steel structure with reinforced concrete columns as a double column on a single foundation. When I want to make a single foundation, two nodes appear. How can I do it. Basically, dilation is a must or not? Good work. Also, when we hold the nodal point of the steel material and say stone, the screen that appears so that we can give the x,y,z distances to enter the distance does not appear. thanks.
"memorandum":2gd0jss5" said:
Greetings, I don't want to dilate the foundation, but it is a steel structure with reinforced concrete columns as a double column on a single foundation. When I want to make a single foundation, two nodes appear. I can do it. Basically, dilatation is a must or not? When we hold the nodal point of the steel material and say the stone, the screen that appears so that we can give the x, y, z distances to enter the distance does not appear. I can't find it. thanks.
The dialog in question may have gone off the screen. Exit the program. From the keyboard, hold down the left Ctrl and the left Shift key. Run the program while holding down the keys. A message will appear on the screen as "login and settings cleared". Click ok on the message, the problem will be solved when the program opens. Good work
Thank you Mr. Hakan. Well, I'm wondering if you should basically dilate or not, while there is dilatation in the superstructure. Good work Sent via iPhone using Tapatalk
"memorandum":1c54570g" said:
And when we hold the knot of the steel material, when we say stone, the screen that shows us the x,y,z distances to enter the distance does not appear. I can't find it. Thanks.
1-This problem was not solved in this way. Do you need to uninstall and reinstall the program? 2-Is it not possible to add purlins to the parts shown in the appendix. There is also a problem when coating. That is, the add purlin or add secondary beam command does not provide continuity between two objects with different lengths and divides them equally. Is there a solution to this? 3-Beams are 100*100*5 but it doesn't seem to save. Is the sprain troublesome? I made it by importing from Autocad. Good work..
Hi, 1- To bring back the Move command window; Before opening the program, delete the files in the C:\ProgramData\ideCAD folder and repeat the process Hakan has mentioned. If the situation does not improve, you can install the Teamviewer program on your computer and contact our office. 2- For the parts you mentioned, you can make the appropriate definition for the situation in your project by using the commands perpendicular to the first and second main part in the offset settings in the layout properties section of the settings of your purlins. When the purlins are formed properly, the cladding elements will also form properly. 3- You can see why your unsaved beams are not saved by examining the details from the Steel design>Beam menu. Good work.
"hakansahin":zg3byood" said:
The dialog in question may have gone off the screen. Exit the program. Press and hold the left Ctrl and left Shift key on the keyboard. Run the program while holding the keys. A message will appear on the screen as "login and settings are cleared". Click OK on the message, the problem will be solved when the program is opened.
It is not necessary to uninstall and install the program again. Run the program while simultaneously and continuously holding down the Ctrl key with your left thumb and the shift key on the left with your left index finger. Do not lift your fingers while the program is opening until the "entry and settings cleared" warning appears on the screen. When you see the message I mentioned ( "login and settings cleared") you need to click OK. If you did not see the message, it means that the reset process I mentioned did not occur. Try again. If not, you can call me from the Bursa office. It connects to your computer with Teamviewer, I can show the process. Tel: 0 224 220 67 17
