Dose still can't analysis dome with the model?
ammer
hello friends
when the new version idecad 9 will release?
and did they solve this issue with the dome???
ammer":imtz2ozx said:
hello friends
Hi Ammer,
1. Dome can be analyzed with model in version 8.62, which was fixed after version 8.5 . You don't need to wait for version 9
2. We plan to realease version 9 till end of 2018
You may see sample project below for dome analysis with model
hello mr hakan
many thank sto your efforts,
kindly check out the attached file for my model with dome
please evaluate the model
and idecad can't output the dome drawings...
thanks
ammer":2qixsyfo said:
hello mr hakan
thanks
Hi Ammer
Please clear check on DS column in Reinforcement Concrete Design Of Dome so program can select reinforcement bars for it. After that, reanalyze project and you can get dome drawing.
In other hand, there is mesh error in your project. You need to check beams - slabs connections.
ammer":3gvprog8 said:
Are these option for the min steel reinforcement?
No, DS means "don't select new reinforcement bars". If you check DS, program cant replace new bars for empty ones or selected ones before
