"Section sizes for all load case combinations can be determined. Transverse and flexural reinforcement is calculated. The calculation is carried out according to the minimum requirements laid down by DIN 1045, DIN 1045-1 or EC2. User-defined entries for the reinforcement proposal to be made such as rod diameter or concrete covering can be carried out manually. The reinforcement proposal can be modified, optimized and printed out as a reinforcement design sketch if required. The cross-section assessment is carried out for stresses relating to shear force, torsion and bending.
The calculation and assessment of suspender beams, bearers, ribs and crosswise bearers in a system are carried out according to the same technique. Rod diameter, number of reinforcements and anchoring length are taken into consideration during the automatic generation of reinforcement plans. "
