Dose ideCAD show the stair section in the drawings
Re: Dose idecad show the stair section in the drawings?
Hi Ammer,
Check "Object Body" Color on Drawing Setting if it's white. Stair section is being showed but you may not see because of it may be same color with background color.
Re: Dose ideCAD show the stair section in the drawings?
dear hakan
it still not showing even though i changed the color to the black,
here you are my file
thanks
Hi Ammer,
There is no stair section on your current drawing as you mentioned yes but I didn't see any problem on stair section drawing after redrawing.
1. I opened your project
2. I got stair drawing. there was no problem stair section lines.
Please let me know if you can't succeed to get stair drawing without problem after redrawing.
Furthermore I want to notify you that stair analysis was not applied on your project. You need to define stair boundary conditions to solve separate stair from building.
hi hakan
kindly send me any stair model made by you...i will try the settings.
I am adding project that you can use. I have just got stair drawing from your project you added
hello
i deleted the stair drawing in your model,and tried to set drawing again,but the issue didn't solve. :( :( :( :( :(
ammer":16f8ks9p said:
hello
I can connect to your pc if you want.
You may send me an email when you are ready.
