"NYILMAZ":3fwl1r25" said:
I think you should add more curtains to the system more appropriate places. In addition, 0.35 for floor fixed loads is not a very high value. If you are considering the joists of the rib floor, they are calculated automatically. No, I can't say anything if not styrofoam but something else was considered as a filling material. Why are you trying to solve blocks that are as separate from each other as the foundation and superstructure on a project? When a single foundation is defined under the big main blocks, the stresses decrease a little more, but it is not enough. There are consoles in many parts of the building. So basically consoles can be made at the same points in a similar way. I think some consoles (ampatons) are too redundant. In the area where the elevators are located, you can make the under-elevator foundation amplitudes 60-70 cm (toward the building), and shorten the building's foundation amplitudes to 80-90 cm. As in the picture, you can make ampathes for S12, S13, S40 columns. I think that the foundation thickness may be a little more for an 11-storey building. With a little work, I was able to pull the stresses down. However, despite all this, I still could not reach the solution (as it is). Maybe it can go to a different solution with curtain solutions and dilatation cancellation as I wrote above. I couldn't try it as it required more effort Note: A raft named D 62 is visible between the rafts. Find object and delete it.
Nedim, first of all, thank you very much for taking your time to review. I entered brick as a filling material. (I tried it with styrofoam, though) The reason why I drew in the same project was that I wanted to draw on one sheet because there are two more blocks adjacent to these blocks, by the way, we can't make a console on the left side. We agree that some parts of the consoles are unnecessary, I will make the necessary abbreviations, I enlarged them for testing purposes, because I have been working on it for a long time, I did all kinds of trials
but since the elevators will have pits there, it will be torn to the floor, so I have made the foundation a little wider with the amplifications and even the main part. I combined. Since the building is very long and L-shaped, I separated the whole mass with dilatation. I am trying to reduce the thickness of the foundation as much as possible. As soon as this ground can lift the load, I'm screaming so that you can heal me
I think it's a separate area of expertise in healing. I think it will be necessary to negotiate with companies that are experienced in this field and solve the problem. I failed in this project because of ignorance
Sent from my SM-G610F using Tapatalk
