aksualigurbuz
take it easy. I have a project in hand and I left two dilatation joints in the project. I basically planned the raft and solved the system. Then (assume there are blocks a, b, c) I took out blocks b and c and solved only block a. But in this case, the tipping calculation He made an error. Well, there is no error in the dilatation solution, but why did it give an error when I solved it alone. And also the internal forces were different. I wonder if I misunderstood something. Isn't the purpose of leaving dilatation to solve each one separately. This is the case, the solution alone is the same as the other solution. Doesn't it need to come out of all forces and other situations. My second question is: according to article 3.6.1.2 of the earthquake regulation, there is a rule that total A g / total Ap will be equal to 0.002. However, that situation does not save me. My choice of R is appropriate in the system, but it does not save the areas. .can we skip this situation or is there a solution. My third and final question: the fret aces (alpha s) come out in the 0.86 state. In this case, do I need to soften the frets a bit? So, is it better to keep all the forces at 0.75 level, not on the walls, and transfer the rest to the columns. Because if alpha s comes out at 0.90, the columns get very little shear. What can you say as a comment to this situation. Could you pay attention to this situation in the projects you have done? take it easy, good work...
                     German
 German  French
 French  Spanish
 Spanish  Portuguese
 Portuguese  Italian
 Italian  Arabic
 Arabic  Russian
 Russian  Japanese
 Japanese  Turkish
 Turkish
