dilatation building
o_berdibek
Hello. I have a project at hand. It is a dilated structure modeled as two blocks perpendicular to each other. the program displays and decodes the system in different apertures. is this normal?
"o_berdibek":1ifjdt6e" said:
hello. I have a project in hand. It is a dilated structure modeled in two blocks perpendicular to each other. The program displays the system in different apertures and solves it. Is this normal?
Hello, Normal... Check out question/answer 11.
How can we draw a panel? Is there a way?
In order to take it into account in the analysis, you can define an arc panel by drawing an arc object with the arc command and giving the sufficient number of parts with the convert to panel command. However, you need to overhaul the panel reinforcement design and drawing.
