Detailed Door Window Drawing
serdagi
Hello, with Idemimar, can we have detailed door and window drawings as in the attached pictures. (The texts can be written in 2D grandfather, but does the profile etc. draw ready?) I wish you good work.
Hello, Door and window design is made in the IdeCAD ODT program located in the IdeCAD folder. Here, you can design the frame and wing elements yourself, apart from the existing profile elements. It will take your time to elaborate as in the image you shared. Our suggestion to you is to draw the degree we have presented to you, and to obtain the detail drawing from the manufacturer and create it in 2 dimensions. Good work
