Deleting elements at different elevations in the same projection
Kdr34
Hello friends; While deleting one of the elements that are shown on top of each other on the plan but defined at different levels (for example, when I want to delete the beam at the floor level, it also deletes the beam and the floor defined at the bottom with the negative level), it also deletes the elements that appear to be connected on the plan defined at the upper level. the situation is the same. What steps should I do to solve this? (In this plan, it would be nice if an option box opens where you can enter the properties of both or delete them directly when you hover over the elements defined on top of each other)...
Re: Deleting elements at different elevations in the same projection Hello, sending objects to the background or bringing them forward with the "Drawing order" command affects the selection of objects. The reason why the D109 slab is deleted when the K270 beam is deleted is because the K270 beam is defined as an edge when defining the D109 slab. While defining the overlapping beam and slab on the same floor, the beam and slab settings should be defined after the elevations are adjusted. Your question in your project has been answered in this message as well.
