Defining Thickness to a Terrain Polygon?
Meakka
Hello, I am working on a project. In my project I need to make a sloping pavement next to the sloping road. I've handled the path with terrain polygon, but I need to define a thickness to the pavement. can i do it with something other than terrain range? Can I do it on the terrain range? There is a problem because the corner areas of the pavement are rounded, otherwise I would deal with the roof edge etc. Thanks Ide version: 7.018 project file:
Hello, you have defined the road as a terrain polygon, which is not correct. First, define the entire land as a single terrain polygon; you should define separate areas such as roads and pavements with the appropriate terrain subcommands. Land clearance for road and pavement, basement and pool areas, land subzone to create an area on land slope. You will understand the logic better when you watch the field training videos from the link
. You can also download and review the sample land project from the link
. In the light of this information, try to create your own land. If you get stuck at a point, we will try to help you again.
