Defining additional load on the roof
mehmetba
Hello. In the project to be done (cattle shelter), it is planned to put solar panels on the roof covering. There will be an average of 65 kg of additional load on the M2, would it be the right approach to add this load to the already load while adding the coating?
Hello there; You can add the solar panel weights to the pavement self-load. It will be the right approach in terms of analysis and design. If you wish, you can also log in as a user-defined fixed load by selecting the overlay and right-clicking - add load - smooth area load. The program will adapt this load to combinations with fixed loads. You can see the load values under a separate heading in the reports. Good work.
