Data exchange with AMP and OSKA Progress Payment Programs
mimsta
In the Building Components section, there is a section called "Download from Amp", how does it work? Also is it just from amp or oska etc. Is it possible to exchange data with other progress payment programs?
Re: How is data exchange with Progress Payment Program? Mr. mimsta; As of the next version (6.5), the commands you mentioned will be removed and integration with AMP and OSKA program will be implemented. When the new version comes out, we present you an information note with the use of this feature. Integration is done simply by reading the unit price list, assigning them to the elements in your architectural project as components, and then transferring the calculated amounts to the progress payment program.
Re: How is data exchange with Progress Payment Program? How to read Unit Price Exposure Lists, I want a file named "ampide" file, I couldn't find such a file in the program folder. Can you add an image about it? Thanks..
Re: How is data exchange with Progress Program? Hello, first of all, in AMP program, Management menu Other[ Enter Transfer program exposure information command under /b]. On the page that opens, select the book name (eg public works) and department name (eg construction market prices) and click Transfer . Here, the extension of the file is transferred as (2011.03 vers), *.ampide in the last update of the program. In the 2nd step, in ideCAD Architecture 6.53 or ideCAD Static 6.53 versions, enter Design building components command from Tools menu. In the category settings dialog that opens, click Install from AMP and select *.ampide transferred as described above. The poses, the description of the material and the units are loaded. After this stage, the objects in the ideCAD programs are assigned the building component and the quantity preparation processes are applied. In step 3 ideCAD Architecture 6.53 from Tools menu Calculations[ Enter /b] and enter Export build component database to AMP and give a file name. The file extension will be transferred as *.ideamp_m. ideCAD Static 6.53 in Tools menu Accounts[/b Click the Export static footage to AMP command under ] and give a file name. The file extension will be transferred as *.ideamp_s. In the 4th and last stage, the Approximate cost calculation command is entered in the AMP program. Right mouse button is pressed in the table in the window that opens. From the right-click menu that opens, the command Get data from architectural and static programs is entered. Here, the desired architectural and static quantities are opened. *.ideamp_m for architectural project, *.ideamp_s file for static project is selected and transferred to the program. Note: To load the reinforcement quantity imported from ideCAD Static 6.53 to AMP, Y[ From b]approximate cost, Iron quantity is clicked. In the window that opens, the reinforcement quantities are integrated by clicking the Get metering data from static program command from the right-click menu.
"mimsta":rw23382x" said:
How to read Unit Price Exposure Lists, I want a file named "ampide" file, I couldn't find such a file in the program folder. Could you add an image about it? Thanks..
