Customize commands based on usage
HakanŞahin
Administrator
If you want to use any command that you use a lot, in a visible place, on the toolbar, you can drag and drop it to the toolbars with "Customize" .
-> Click the right mouse button on any toolbar. Click on Customize from the drop-down menu.
-> In the dialog that opens, reach the command you want from the Categories section. For example, select the Report from the Categories section.
-> Select the Curtain Group line, for example, from the Commands section, drag and drop it to the desired toolbar by keeping the left mouse button pressed.
-> After closing the customize dialog, you can use the command by clicking the command in the toolbar you placed.
