Curtain Purchasing rate is too high
hmym
In my attached project, in my U-section group curtain that I created around the elevator, there is excess reinforcement density on the curtains on the ground floor. Can I check the system in general and get your ideas and suggestions. Thank you
Hello My suggestion; Curtain group bending did not save the design. attached. What to do: Enlarge curtain header areas Increase header area reinforcement area If these are not enough, you add curtains. Unver ÖZCAN
Hello... According to your structure, it seems normal to me. The floor is high, the curtain is low in the weak direction of the building, the only curtain running in that direction is P006, moreover, there is 4/5R. Pursanta may be high, I think, put it after the maximum is not exceeded. You can increase the diameters. Sometimes I see that there are those who say that the program is calculating incorrectly and reduce it :) Good work...
