I calculated the minimum transverse reinforcement in the curtain end area according to tdy 2007, but this value does not match with idecad. Idecad solved it with 8 reinforcements, I found 12, the minimum mistake I made, I uploaded the calculation as a picture.[/quote ] Hello, Stirrups cannot be larger than 10 cm along the critical wall height on the curtain end curtains. The program always complies with this condition. Have you seen the fi8/20 stirrup outside the critical curtain height? The mentioned item is valid throughout the critical curtain height In addition, the stirrups coming from the middle region of the curtain are taken into account as present in the end regions. (This situation is optional in the 8 version.) You should also deduct the value of the stirrups in the middle region in your account. If you add the project of the curtain you take into account, we can look at the situation in more detail.
