Hello, Yes, it can be created. The beam to be referenced can be selected as an oblique beam, or the reference line can be determined obliquely."cakilomer":z0e46g40" said:Is it possible to cast a transverse rib between ribs in idestatic, as I indicated in the picture, from column to column
"Levent Özpak":1utt9tqo" said:Thank you, Mr. Levent, good work"cakilomer":1utt9tqo" said:Is there a possibility to cross ribs between ribs as I said in the image, crosswise from column to column[ /quote] Hi, Yes it can be created. The beam to be referenced for the transverse tooth can be selected as an oblique beam or the reference line can be determined obliquely.
