Hello, I am creating a library using the 3DS extension objects I have with iderender. My problem is that before saving the object, it is necessary to define a corner point.
Re: CREATING A NEW LIBRARY Hello After you create a plan with the automatic create plan command, you can add a snapping point to the 4 corners of your object with the definition point command.
