I want to furnish the rooms on the floor plan and save them as 3D and textured jpg, but I can't save them in the 3d window. It's working as a 2d plan, I can't write the location names in 3d. You can transfer your project to ideCAD render in order to render and create 3D text.You can run the ideCAD render command from the dialog that opens by right-clicking on the perspective screen.In the interface of the ideCAD rendering program, click the left button once on the workplane named above and then click the render command.You can render your render from the plan like this. For 3-dimensional text, click the text command, select the plane you want to work on, for example, the top view. To adjust the height in the Z plane, you can change the nodal points when you select the text in the front view and double-click.
