Hello, When we divide the crane system into two as the calculation of the crane beams and the loads to be affected by the cranes and the calculation of the carrier system, these two calculations are calculated by the software after the information such as the number of cranes, their locations, wheel loads, distances between the wheels, bridge and cat car weights to be defined by the user. I know that it can be done automatically in line with the specifications and these features will be actively used in the upcoming beta versions. It is also possible to define different levels of cranes in a hall. I know that the definition of cranes with more than one different capacity on the same line and also in the side halls can be made in accordance with the conditions in the relevant American specifications and these features will be put into active use in the upcoming beta versions. I know that all vertical/horizontal loadings related to the crane are made automatically by the software in accordance with the conditions defined in the relevant American specifications, taking into account the crane weights, which are the basis for earthquake loading. In addition, all vertical/horizontal loadings are presented to the user after analysis with direction/position/result information that can be visually understood. I wish you good work.
