A ammer New Member Oct 23, 2019 #1 hello friends i would like to know the correct option for the beam or wall connection to the column and is it correct in the below image? or must be connect the beams and the walls to the center of the columns ? thanks
H HakanŞahin Administrator Oct 23, 2019 #2 Re: Correct option for the beam or wall connection to the co Hi Ammer, It's not required to connect the walls or beams from center of the columns. The connections on the image you added is no problem.
