Delete the column and replace the curtain with the curtain. You can delete it and replace it with a colon.There is no command in the program to convert from column to screen or from screen to column."qwerty":2wh0hl5z" said:When I want to remove the curtain in my project and put a column instead of a column, it is very tiring to do this. Can you help me if there is an easy way to do this?
"ozdemirhasan35":2tdvng31" said:there is a serious problem in big projects, it would be great if such a convenience is provided.
Thank you. Can you help with the above question?"Arzu Dural Gök":lbs7d7x7" said:All answers with ideCAD avatar are answered by ideYAPI technical team.
"qwerty":2myl74hj" said:Thank you. Can you help me about the question above?"Arzu Dural Gök":2myl74hj" said:All answers with ideCAD avatar are answered by ideYAPI technical team.
You have been answered before.Use the "move node" command on each floor to extend the length of the screen with the nodal points."HakanŞahin":2myl74hj" said:Dear İde, Is there a more practical method you can suggest?"qwerty":2myl74hj" said:When I want to remove the curtain in my project and put a column instead of a column, this is very tiring is happening. Can you help me if there is an easy way to do this?You can delete the column and replace the curtain with a curtain, and replace the curtain with a column. There is no command to convert to a column in the program."qwerty":2myl74hj" said:To remove the column and replace it with a curtain or vice versa? To extend the length of the curtain with knots on each floor
You can delete the column and replace it with a curtain, delete the curtain and replace it with a column. There is no command to convert from column to curtain or from curtain to column. Use the " command."qwerty":izxy7f3o" said:I remember your previous answer and thank you. Since you are much more familiar with the skills and commands of the program, I moved the topic to the second part: My current question is, depending on the current situation (converting a column to a curtain or a curtain to a column in the program). command), how can I make the following applications more practical? Is there a more practical way to remove the column and replace it with a curtain in a 12-storey building or vice versa? Is there a more practical way?
When it is deleted to convert, the connected floors are also deleted together. If this is meant; In this case, instead of deleting the curtain (by right-clicking on the curtain) with the convert to beam command, converting the curtain to beam and adding the considered column facilitates the process. Good work..."qwerty":2bnu3cb8" said:When I want to remove the screen in my project and put a column instead of a column, it is very tiring to do this. Can you help me if there is an easy way?
Curtains can be defined as rectangular section. Parallel edge cannot be defined in the section, such as parallel edges.You can edit the drawings with 2D drawing tools after you receive them.The request to trim the curtain edges is in our notes."3428":2b9h221c" said:https://we.tl/t-tEnVAUrdvW I have to define column S17 in the picture as curtain in a project. is there a way how can I do it?
