Continuous Fundamental and pitch error
damlatpz
Good Day I am having trouble with the drawings because of the basement curtains that I always turn to. I face the same problem when I close the curtain and get a drawing. I added the project. I would appreciate if you help, good work.
It is known how the drawing is taken. There is a problem in the mold, basically in the column application. etc...
"damlatpz":arvg16l7" said:
Good Day I'm having problems with drawings because of the basement curtains that I always turn to. I also face the same problem when I close the curtain and take a drawing. I have added the project. I would appreciate your help. Good work.
Hello, in the reinforcement selection dialog No reinforcement diameters are selected for the vertical walls and the vertical end zone. This is the reason for the problem. Good work
I had the same situation, but my continuous beam is 255 cm longer after the column, do you think this is a normal situation. Also, in one of my projects, the length of the continuous foundation beams was infinite. What is the reason?
Hello Mr. Bakil, if you add your project by giving the beam of 255 cm and the number of the foundation beam, we will see. Unver ÖZCAN
