Container Design
serdagi
Hello, I wanted to design a container with idestatic steel. I don't know if the program is suitable for making such a design, but when I analyze the drawing I made in the attached data, it gives a warning to check the geometry and the analysis is interrupted. If we can do such an analysis in the program, why does the error occur? I wish everyone good work.
Hello there; The reason why you get an error during the analysis is that your beams at the lower level do not have any support and therefore the elements that need to work against bending and shear force as of your model are not supported by a support such as a column. You need to create suitable support conditions in the part of the steel beams on the lower level that rest on the ground. You can see a big red arrow after the analysis on the perspective screen, this arrow shows you where and from which node the error originated. The geometry control is functional in reinforced concrete, for steel you need to edit the point where the red arrow points after analysis and similar points created in the same way. Good work.
