Hello, It gives an overlap error in the joints on both sides of the column and beam on the same level. You can also see the overlaps in the butt plate shear joints in the columns and in the purlin joints in the beams in the project I added. Can this cause problems during production or construction? Is there a solution to this? Thank you...
