Sadi Özsaraç
Hello, there is a section that stuck in my mind, I would like to share with you and get engineering advice. For the combinations used in steel calculations -G+Q combination and G+0.5s combination are used for the purlin deflection calculation. -Many combinations of earthquake loads are used for beam-column strength calculations, etc. For example, the İdecad program checks the diagonals. It reflects the most unfavorable situation to the results according to the strength and slenderness ratios. In the joint calculations of the braces, the joint calculations are made according to the axial force. The first thing I want to ask is, I examined the calculations made by Idecad on a project. When I look at the section effects section, the Axial force value in the combination used for the joint calculation is not made according to the most unfavorable axial force. There are combinations that are greater than the value used in the calculation (for example, roof braces). So as engineers, which combinations should we use in the combination calculations? Is there a special section in the regulation for the combination calculation, such as the purlin deflection calculation? Or are the steel combinations we use in the general strength calculation valid for the joints? Or should the most unfavorable combination used in steel strength be used for the joint calculation values? As you know, Idecad de Guse combinations cannot be calculated. But Butt Plate joints can be solved in Idecad. I saw that the controls used for the butt plate joint calculation are similar to the Guseli joint. (controls for column body leakage, column body wrinkling, etc.) 2- Is it necessary to define the gusset joint as a long forehead plate and use the most unfavorable value among the combinations given in the design report in the joint calculation, or are there specified combinations for gusset or butt plate joints? I would like to get the opinions of you esteemed engineers, Have a nice day
