Hello there; It is not possible to connect two separate trusses to the column with a single joint. You have to enter the brace combination separately and manipulate the drawings manually. In the same way, if you are going to combine the top headings, remove the cover part of one of them from the additional features tab of the scissor properties in the relevant direction. For joint, use welded joint. With the welded joint, more than 2 different oriented elements can be connected, each time you move to a different direction, right click with the mouse.
