Column Vertical Expansion Drawing Errors
platon24
The attached pdf has the vertical expansion detail of a column. The dimensions of the column in the basement are 150 x 100 and the continuation on the upper floor is 60x60. As can be seen in the pdf file, the drawings of the accessories are incorrect. And the length of the anchor reinforcement is longer than given in the foundation application. Is this a mistake? Or is it normal for the anchor reinforcements to be different? . I think the reinforcement drawing and sizes are wrong. Is there a solution or do I have to fix it manually? Thanks.
Hello. longer. Is this a mistake. Or is it normal for the anchor reinforcements to be different? fix it, --Delete the anchors in the basic application plan (According to the TDY2007 regulation, I reported this to beta users, it will be fixed in the upcoming versions.) Ünver ÖZCAN
