Column join conflict check
leyla12
Hello. In my 4-storey steel building, I connect the columns to each other with column attachments, but I always get an error on the side plates of this combination during the overlap check, I wonder what could be the reason? It doesn't matter if it is welded or bolted, I keep getting an error.
Hello there; Your project file appears to be corrupt. If you open a new template project and examine it, there is no conflict problem in the combinations created by the program in the default. As an example, you can use the project we created in the appendix. Good work.
