hello, I got a column beam shear safety error in my project, then I fixed them, this time the floor offset in the y direction was too much. I went back to the beginning again. Could you please help me with this. Also, I drew the foundation and made a sub-basement curtain on it, and it will be filled. I'm uploading the architecture, can you take a look at the project? Is there an error in data entry?
Hello, The findings and suggestions for your project are generally as follows; Base not defined under column S6. -TK02-TK03-TK12 continuous foundations are not connected to columns. It is appropriate to enter data with the continuous basic nodes on the column. -Some of the basement curtains are attached to the floors at zero level. After defining the beams and floors at the floor level, adjust the upper levels from the Shear settings and redefine the basement curtains. -K09 beam is not connected to S10, K38-S12, K41-S13, K42-S14. -You can review the link below for the solution of the column beam joint shear safety problem.
