Column Beam reinforcement insufficient error
Hi Suggestion project is attached. You can add sub-basin curtains to the modeling by leaving 2 cm space on columns and curtains. Unver ÖZCAN
Hello, Some notes with the project: -It would be appropriate to select the 'Short head curtain' option from the properties of the curtains named SP6 and SP5, which are in the curtain group and do not provide the 1/6 aspect ratio. - If you remove the reinforcement fixings from the element reinforced concrete dialogs and analyze, you do not have a member with insufficient reinforcement in its current state. - Belt beams are constructive elements that are not included in the analysis, used for drawing additional reinforcement in the free ends of the slabs in the tunnel formwork systems, in the formwork plans. - In the final analysis, we recommend making the analysis by reducing the width of the slab, curtain and raft finite element. (For example 25 cm) Good work.
