Coefficient problem in calculating concrete value in Risky Building Analysis
mehmetalkilic
For the risky structure analysis, the concrete strength, which is 12.85 Mpa, is seen as 10.8 in the control parameters. Since the knowledge level is minimum, it should be 12.85*0.9= 11.56 Mpa. What is the cause of this problem?
Re: The coefficient in the calculation of the concrete value in Risky Building Analysis is so When I downloaded your file, made a risky building analysis and received a report, I saw it as 11.565 Mpa in the control parameters table.
Re: Coefficient in calculating concrete value in Risky Building Analysis so Hello, Knowledge level "Minimum" is selected in risky building analysis. In this case, the current material strength defined by the user in the building tree is multiplied by the Knowledge level coefficient specified in Risky Building Regulation Table 4.1. Concrete strength defined in the Building tree in your project is 12.85Mpa. When the risky building analysis is made, it appears as 12.85*0.9=11.565 Mpa in the risky building analysis report.
