Re: SHUT DOWN PROBLEM Hello, The cause of your problem may be related to the video card. (We recommend that the video card has an nvidia chip.) Update the video card. If you are using the semi-rigid diaphragm solution, the computer may be running out of physical memory. For semi-rigid diaphragm solution, we recommend at least 8GB and optimally 16GB memory. If your problem occurs on a project basis, we will need to see the project.
