Hello there; Define the new steel material from the materials tab in the building tree. Then, double-click the section you want to use from the building tree - sections tab and change its material. Then enter any steel command for steel column, beam and call the same section again from the section library. In this way, the same section from two different materials will be listed in the building tree. Good work.
