change element properties
ERKANŞIKTAR
Can different column, beam or curtain properties of reinforced concrete elements be entered in the same project. For example, can we make the elasticity of one column different from the elasticity of another column?
"erkansıktar":2cfnyobx" said:
is it possible to enter different column, beam or shear properties of reinforced concrete elements in the same project. For example, can we make the elasticity of one column different with the elasticity of another column.
Right-click on the materials in the building tree and click "Add New Material" You can create more than one material in your project with the " command. You can use different materials you have created in columns, walls, beams, etc. in different elements, and thus you can make the elasticity of one column different from the elasticity of another column. Material selection in the Static tab in the element properties You can do.
