Thank you, the problem was caused by that slab. I guess I can't connect that slab edge with the beam, more precisely, I don't know if there is a trick to combining the slab edge and the beam."Levent Özpak":1yxhtvou" said:Hi, The upper floor edge of the D04 slab in the basement floor is not connecting to the K14 beam. Enter the slab edge so that it connects to the beam and recreate the slab. Good work
The "divide by intersections" option must be active in the beam helper toolbar."brkayacan":2udaqkov" said:Thank you, the problem was with that flooring. I just can't connect that slab edge with the beam. More precisely, I don't know if there is a trick to joining the slab edge and the beam."Levent Özpak":2udaqkov" said:Hi, The upper slab edge of the D04 slab in the basement is not connecting to the K14 beam. Rebuild the slab by entering the slab edge to connect to the beam. Good work
