Can I do this in ideCAD Steel?
Apocalpyse
Hello, Some building inspection companies want me to prepare a plan like the attached. They were used to seeing a column application plan, so they did not consider the anchor plan sufficient. Can idecad make an update on this? I personally created this plan by taking a normal column appl, deleting everything except the axles and dimensions, saying "Get a 2D drawing of I profiles" on it and copying and pasting it from there. I also wrote IPE240 at the beginning of the columns. they had enough. When I bought the direct column apl plan, it could not be understood because it was visible on the anchor plates and flag plates. Thanks for your interest.
Hello there; Application plans; It is formed from the elevations in the floor general settings. In addition, you can define the level of the steel drawing settings for the level you want and get a drawing. For example, 50 cm etc. if they do not want to see the anchor placement. By getting an application plan from one point, you can only draw columns. Or you can save the project as a different application plan after deleting the column feet. Or you can edit the negative and positive depth so that other elements are not visible. In short, there are solutions with different alternatives. Currently, only the pose number is assigned to the columns in the plan drawings, and notes are taken to include the section names.
Thank you for your interest, Ms. Nurgul. So how do I make the tension rods appear on the roof plan? Can it be written on the reinforcement automatically?
